cambsno
- Simon
I wonder if the camera is OK...
Was she shooting raw or jpg?
A relatively new format, a combination of RAW and JPEG; JAWsWas she shooting raw or jpg?
While she should probably be on the Darwin Award list and is undeniably rather silly, she has lost both hands...
Yes, absolutely agree.While she should probably be on the Darwin Award list and is undeniably rather silly, she has lost both hands...
..a phone, I assume. So,she tried to engage with it,then ? It's been suggested it was a Bull Shark,one of the most aggressive of the species. There are quite a few species of sharks around those islands and if it was aBull shark then that is not one of the common ones. Another species thereabouts, but also not common,is the Tiger shark,also aggressive. There's no-way you'd get me swimming in waters where it's known that sharks abound.
There are sharks in pretty much any body of salt water - even round the British coast. The species regarded as dangerous are rare but not unknown!
There's no reason why you can't drop the voltage of the big battery by any amount you choose, given the correct circuit.The electric batteries on electric cars are somewhere around 300 to 400 volts, a 12 volt battery is needed for lighting on systems etc.
Well, if the ICE vehicle has a dead battery and you're on a hill, you might just get it going (I did that once).Just like ICE vehicles...
To my mind you need the 12V battery to power the relays that allow isolation of the main batteries when not in use.
I have a Noco Booster battery which fits under the front seat which I use to jump start the car, There is a point in the fuse box to connect it to.
You need to keep it in the car as there is only 1 manual key point on my Toyota.
I got the Booster as we sometimes go away in winter and did not want to return to the airport parking to find a flat battery in the middle of the night.
How do you find the NOCO booster? Very tempted to get one as insurance against flat batteries but not sure which to get! At the moment, it would need to cover up to a 3l Diesel but that is subject to change! FWIW, the 12V battery in the iPace is the same as a 1l Corsa.
My car has a lever operated parking brake and I imagine that "bump starting" would suck enough fuel through to get the alternator spinning. After that, it should be fine....the car needs enough oomph in the battery to power the fuel pump as well as release the parking brake. No use in an automatic either.
I have one rated to 7l petrol/4l diesel for my Defender. 27 year old 200K 2.5l diesel and yes I've had to use it a couple of times. Just adhere to the charging interval stated in the manual even if you think it doesn't need it ie do not just stick it somewhere in the car and forget about it. Your only hope of bump starting a Defender is down the side of a mountain![]()
I have a NOCO GB40 which is supposed to be good for up to 3L diesel. Flat 12V batteries are not uncommon with Hybrids, they also have small 12V batteriesHow do you find the NOCO booster? Very tempted to get one as insurance against flat batteries but not sure which to get! At the moment, it would need to cover up to a 3l Diesel but that is subject to change! FWIW, the 12V battery in the iPace is the same as a 1l Corsa.
Unlikely these days - the car needs enough oomph in the battery to power the fuel pump as well as release the parking brake. No use in an automatic either.
Yes it's a NOCO. GB50 I think.Thanks for that, Jan. Is yours a NOCO one or another breed?
My old S2a Diesel was comparatively easy to bump - didn't need to be switched on! Never tried the 90 (200TDi).
I have had to use it a couple of times so far with no problems, only needed in winter when it's always dark and the lights are used all the time and the car is not used often. For a hybrid it only needs to supply a little bit of oomph. I have the GB40.How do you find the NOCO booster? Very tempted to get one as insurance against flat batteries but not sure which to get! At the moment, it would need to cover up to a 3l Diesel but that is subject to change! FWIW, the 12V battery in the iPace is the same as a 1l Corsa.
most spam just guesses email addresses as you've guessed.Is this just to see if my Email address is live.? What would have happened had I clicked on the link ?
Replying or unsubscribing does as you say, shows its real and live. They will then put you on other, what they call, mug lists.
When you see an add on your browser, look in the top right corner. If you click on the triangle you can see who will have your information. If you drill down further, you will find who those , in turn pass it too. It will scare you.Thanks,Brian. I don't think my Email would be a guess, though. They've ,surely, got it from somwhere. I've never heard of Uk Best Deals.
What have things come to when the best way to keep safe is to not open any Email you don't recognise having come from a known source or don't answer the phone when you don't recognise the number displayed. When the option comes up to 'accept cookies' or 'essential cookies only' it best to reject them ? I clear websites/caches every couple of days. I assume that gets rid of them all and any information they contain.
Why do we have a hole at the bottom?Why do hot water bottles have a hole at the bottom?
To hang them up? to also drip dry.Why do hot water bottles have a hole at the bottom?
Well, mine is only half way down...Why do we have a hole at the bottom?![]()
UK bans EU cheese and meat imports to prevent foot and mouth disease spreading
People coming into Great Britain can no longer bring cured meats or cheese from the EU following an outbreak of foot and mouth disease.www.bbc.co.uk
So I cant buy a salami or other type of meat to bring home, but we as a country can still import meat etc... I dont see the logic in doing one and not the other? Why would bacon I buy in Lidl in Cyprus be more dangerous than bacon shipped from a Danish plant?
Wouldn't it? I can understand if bought at a farmers market but if in a supermarket like Lidl, how would it be different to the stuff Lidl brings in?No-one knows where the meat you might bring in by hand came from - probably not even you. The meat from an importer will have had to have vet certification and a paper trail demonstrating origins and showing it came from disease-free livestock. It *could* be falsified, but would be somewhat difficult to do.
FWIW I notice German salami has completely disappeared from all supermarkets round here.
