- Neil
That's what windscreen washer/wipers are for.So why do the petrol stations remove the pin in the handle so you can't clean the screen while letting it fill up?
All pumps automatically shut off, so how can you put too much in?
Why would I only want to put in £30? I run the tank down until the 50 mile/yellow light comes on then fill up again. Anything else is false economy. I knew someone that would just put in £2.00 worth every morning on his way to work (it was a few years ago) not only was there no advantage to this, he'd often be late for work because he had to stop for fuel on the way or he would run out.Because maybe you only wanted to put in thirty quids worth.![]()
b****r!Ummm - you SICK your fingers up ???
Me mind boggled![]()
You can't, you trickle feed and stop when you've reached the amount you want, or you just fill up. Simple enough.The reason is immaterial.
You said yo can't dispense too much fuel when quite clearly you can.
Sorry if that doesn't sit well on the planet of Nilagin![]()
Some people may have better things to spend their money on, rather than a "full tank"Why would I only want to put in £30? I run the tank down until the 50 mile/yellow light comes on then fill up again. Anything else is false economy. I knew someone that would just put in £2.00 worth every morning on his way to work (it was a few years ago) not only was there no advantage to this, he'd often be late for work because he had to stop for fuel on the way or he would run out.
You squeeze trigger, tank fills up, when fuel reaches nozzle it shuts off. You can't put in too much. Simple. Only way is try trickle feeding it then it over flows, hence too much.
There is a garage local to me, that 9 / 10 times always jumps 1p when you put the nozzle back in
No matter how much you argue, they claim that I had "used" that 1p's worth.
I did however find a solution though.
I started telling them I would pay the penny but would report them to "weights and measures"
Or what ever its called these days.
Its not the "price" its the "principle"![]()
Once the tank is full it's there to be used as and when wanted, no going back to the petrol station for more earlier than needed because you didn't fill up, it won't go off over a few weeks and the additional weight will be negligible to mpg.Some people may have better things to spend their money on, rather than a "full tank"
Lets face it, is not cheap these days.
A "small journey" user may well have 50 quids worth of fule sat on the drive for weeks,
May as well buy a fresh batch as and when.
Google tells me that
8.3 pounds for an imperial gallon of diesel .
7.29 pounds per Imperial (UK) Gallon
Why carry around the extra weight if you don't need too?
And as for being late for work, due to a fuel stop,
The "7P's" rule applies
As for me, no preference sometimes I'll fill up, sometimes £20 / £30 's worth.
The rest of my pedantic post aside,I have no idea what the "7P's" rule is.
Which translates to, fill up the tank and save unnecessary, time wasting trips to the petrol station.The rest of my pedantic post aside,
Proper, Prior, Planning,
Prevents, p***, poor, performance![]()
As I pass them regularly, so its of no consequence to me either way,Which translates to, fill up the tank and save unnecessary, time wasting trips to the petrol station.![]()
Its almost as good as, what side of your toast do you butter?
The things *we* "argue" about on TP Eh?
But is that the top or the bottom?The side on which it is going to land on?![]()
That goes without sayingNormally the side that hits the floor first just after you've buttered it (n)
but I was actually referring to your colleague,
He needs to plan his day better if he intends to make regular fuel stops.
PMSL a reliable chapMy work colleague certainly was a strange one, it wasn't just stopping for fuel which would make him late, One morning as I walked out of the car park, he was driving in. A few hours later at morning tea break, someone mentioned the colleague not having turned up. I told them he'd driven passed me in the car park but no one had seen him since, next day we found out he'd fallen asleep in his car in the car park, woke up, felt it was too late to go in to work and went home again.
Cool. I shouldn't eat so much TBHAs for toast and butter, neither, I don't eat bread.![]()
OK I'm curious to know what happens if its an odd number?I have to count steps as I walk up or down stairs & they have to finish as an even number
Oh yes , I have a few......
I have to count steps as I walk up or down stairs & they have to finish as an even number & I have to start going up or down with my left leg![]()
I'd completely forgotten about that one probably because I do it without really thinking about it.If I'm walking towards stairs - as happens at work -I adjust my gait to ensure I start going down with my left foot![]()
PMSL(I save the going back up and down the stairs for re-aligning the light switches)
& the loo roll has to roll from the back !
This thread has revealed a whole world I didn't know existed. I never even think about how the loo paper is arranged (althoughI'm pretty miffed if there's none there when I need it). As for counting steps or thinking about petrol???? Light swtches? - I'm not sure I even know which lights in our house have more than one switch.
I walk up staircases two steps at a time, can't say I've ever come across an odd step.I'd completely forgotten about that one probably because I do it without really thinking about it.
But Lynne, you're not the only nutter who does that!
Count steps - yes
Start with left foot - yes
But surely they have to finish as an odd number.
Most domestic staircases have 13 steps, so if you're stuck on the even number thing, that must drive you insane.
