realspeed
- Bazza
- No
I have tried two different USB port plug in WIFI connect units by different makes and initially they worked fine. However given 2/3 months use they started to fail in part. I normally get a download speed of about 15.50/15.80 MBPS but this kept dropping drastically to about 5/6MBPS. I kept trying to correct by resetting and also disconnecting via removing the USB units but the same thing keeps happening. Luckily I still kept and internal card (Edimax) and the 2 aerials that came with it. So ran the program disc and put in to router password and at the moment things are going ok with a signal strength of around 78%. OK not 100% but this computer is in another room from the router so I didn't expect a perfect signal strength but at lest this EDIMAX does let one know which is more than the USB plugin units do, and also frees up a USB port at the same time. So fingers crossed the problem of half intermittent download speed gone
