skysh4rk
- RJ
- No
Hi all,
I was hoping to get some help regarding an issue on a roll of black and white I developed today. Through the entire roll, including between frames, there is a dark streak on the negatives, shown as a light streak on the right side of all images below. Yesterday I developed a roll from the same camera and chemistry (developer was mixed for each respective roll, but stop and fixer re-used) and everything was fine. The only difference I can think of between those two rolls is that the temperature of the chemicals was lower for the batch today, as room temperature was lower, but I adjusted development time accordingly.
I used fresh HP5, pushed three stops in Ilford DD-X. The stop and fixer had been used to develop two previous rolls that came out fine. It looks rather like a light leak to me, although I can't think how that would have happened and I've never had a light leak issue before. My other thought was that I might not have enough chemical in the tank, but I used the same amounts I usually do and the right edge of the images below seem to look fine...
Any thoughts? I thought I'd try to get to the bottom of this before I develop the next roll.
Thanks!
Thanks!
