Box Brownie
- No
Re: the spurious numbers ~ I have seen some that appear to be UK based but a search only throws up such number(s) far away from UK shores :banghead:
Annoying. We have had a few where they all used the same first 5 digits so it was easy to stop those. I have set our phone up so that all incoming calls that are not automatically blocked & are not in our contact/VIP lists are asked to announce their names, this foxes the automated calls. I also block international calls.Seems to be a different number entirely each time.
I would rather shove the gearbox where the sun doesn't shine. He is just lucky that we have a half hour gap between shifts and we never have to meet.Could you leave a chunk of ‘birthday, anniversary?’ cake for him, laced with laxative.
We have had similar calls using the same area code as ours so it's obviously something that is becoming more widespread.Here’s one that’s tricky to block I had 2 calls this morning from different local numbers. It’s a small exchange about a mile from me and only serves the small town and a rural area. The few local numbers that call me are in the memory. If it’s a one-off (like a shop) they don’t have to put in the area code, so usually shows just the local part (why would they dial an extra 5 digits?)
I said “Hello” to the first one because I was expecting a delivery (though usually they are mobile numbers) and a male “English” voice (could easily be taken for, say, policeman) told me I’d been retorted by the National Crime Agency for misuse of electricity & internet etc etc, so I hung up. Second one disconnected as soon as I picked up but didn’t speak --usual practice.
Interesting thing is a friend on the same exchange had a mystery local call this morning too. Occurs to me if they are spoofing numbers it might be easy to get the machines to spoof a number with the same area number they are diallin, more convincing.
That is usually an automated call, they dial several numbers at once, as soon as one of the numbers is answered, the rest go dead. You were too slow to answer.Second one disconnected as soon as I picked up but didn’t speak --usual practice.
Mild annoyance.
Every couple of years, I have to do a load (around a 5 pack box of paper) of shredding and that means that the machine overheats a few times, despite doing the job in several batches. What annoys me is that it always goes into overheat mode half way through a set of sheets - why don't they set the limit a fraction lower and stop it before it gets a fresh load in? Stopping half way through a "grind" means that it has to restart under load, a recipe for stripping gears etc..
I surmise I state the obvious......
Use reverse to remove the half chewed lot once the overheat light goes out.
And regular use of light machine oil! NB our first shredder destroyed itself because I failed to oil often enough![]()
Got an old bottle of spray olive oil (extra virgin) so it gets a squirt of that every few bucketsful. Reversing is OK on this one (cross cut) but actually killed the last one - it completely clogged it!
My mother in law once recommended WD40 for her sons squeaky brakes on his bike; thankfully he decided to avoid her advice.
I'm not surprised. Olive oil goes sticky and some increase in viscosity - it isn't meant to be used as a lubricant.![]()
Doesn’t work because eg Doctors, Hospital, Police all with old numbers. I know they are automated calls and what works is picking up and waiting for them to speak which humans usually do, the machines can’t tell if it’s another machine (eg answer phone) or you playing the system ;(,That is usually an automated call, they dial several numbers at once, as soon as one of the numbers is answered, the rest go dead. You were too slow to answer.
Best way to block nuisance calls is, if you don't recognise the number, don't answer the phone. Works well in our house. If you are expecting a delivery, they usually text or email anyway.
That is the handset we have, only the really desperate continue the call, and I weed them out because it’s an unknown number on the screen. Only a couple of calls come through a year now.We have had similar calls using the same area code as ours so it's obviously something that is becoming more widespread.
On our landline with BT 8610 handsets, those callers not in our block lists , contact or VIP lists have to 'announce themselves' to our phone before the phone handset will ring, when the handset rings & we pick it up it plays their announcement & we can either accept the call or hang up. Very few callers bother announcing unless they are legitimate.
I've always found lightly squeezing the sleeves on the edges just below the point where the CD touches the edges, the sleeve will open, then place index finger and thumb into the sleeve on opposing sides of the disc and get hold of the disc by the centre hole and they come out with ease.CD's in carboard sleeves are annoying me because some are so tight it's a struggle to get the CD's out without gripping them tightly and pitting finger prints on them. Just a few more microns in every direction please!
1st world problems eh?CD's in carboard sleeves are annoying me because some are so tight it's a struggle to get the CD's out without gripping them tightly and pitting finger prints on them. Just a few more microns in every direction please!
I have a few box sets as well as individual albums that are in card sleeves. They all grip tight enough to stop the CD just sliding out on their own, but come out easy when I use the method I mentioned.Tried the usual. What works best is trying to get a finger into the packet to reach the hole and pull the disk out. The offender is the box of Beatles CD's I bought recently, they're just incredibly tight.
Out of the way for everyone, plus it's against lockdown rules.Can you leave the car and get a mate to pick you up and drop you off ?
Sorry not thinking.,Out of the way for everyone, plus it's against lockdown rules.
Ebay have a copyright infringement reporting system. Would that be any use?
yeah, Im waiting for something to come in the post first though, I have a plan.![]()
I've had that before and it's always been a yellow / golden colour and feels gritty. This stuff is a very fine grey powder. Fortunately came off easily with a detailing spray and thick microfiber cloth.Most of the dust in UK rainfall comes from the Sahara. The sand is lifted by strong wind and or storms and carried towards us by the southerly wind. Moisture condenses around those particles to form rain that then falls on to nicely polished cars or freshly cleaned windows.![]()
