mikeyw
I had a tricky task today to shoot some operatic photos mainly on a staircase so I used a SB600+ stofen difuser to give some forward light where there was little ceiling to bounce off. They've worked reasonably ok
However I had to get some quick results with the same setup in an area with a lower ceiling and this yielding a lot more shadow than i expected. I was shooting with the flash at about 60degrees up - maybe i have to shoot 90degrees to reduce the shadows to an absolute minimum but still get some light to the subject faces from the front and not just above ?
Any thoughts here if I can achieve very little shadow with the stofen + sb600 in this sort of shoot with lower ceiling ?
