Matblack
- Matt
I've picked up my 40d yesterday and I have to say I'm delighted with it but I have one question.
Looking through the viewfinder I have the small spot metering circle in the center then the AF points surrounding that but between these and the periphery of the viewfinder I seem to have another quite indistinct but still visible circle, its not a thin black line like the spot metering circle more like a frosted area. I've removed the lens and looked through the viewfinder and its still there, so its not the lens nor does it appear to be on the mirror when I look into the body, its not in the sensor, I've checked it by locking up the mirror using manual sensor clean, however if I look into the mirror (not locked up) I can see up into the camera and the ring is there on the next stage where the squares showing the AF points are.
Is this normal or has there been an issue with the manufacture of some part of my camera? I can't take a photo of it but because its too far inside the camera.
Thanks in advance
MB
Thanks in advance
MB
