viv1969
- Bat-Frog
- No
Yeah, I'm waiting to be called an 'Exif Denier' - I can see the torches being lit for a burning![]()
To be fair, you yourself have provided the kindling.
OKAY- as you won't share, see if this helps...="Awgydawg, post: 7791357, member: 85637"]="If you're not happy with what you get here, there are other forums.....![]()
Mmmmm.... If you don't like it here, go back to where you came from? Where have I heard that before?
Did I say I didn't like it here?
I just made a suggestion which may help people to learn to take better photos. Exif data helps me, this is my opinion.
1-125-f10-1 by Phil Vaughan, on Flickr
Mount-Pleasant-Sneak-peek07 by Phil Vaughan, on Flickr. Exif data helps me, this is my opinion.
And to prove the point......
because, ultimately, an image WITHOUT some sort of message (either implied or overt) is pretty much just either eye-candy or a record shot. neither of which, I personally find appealing, either to look at or to spend time making.
... but they are posted in context. If you had posted them and said "do you like my photos ..."And to prove the point...
I posted 'a record shot' and 'some eye candy'![]()
How, exactly, does it help you?
All it does is inform you what settings were used for that one shot.
Unless you're planning to go to exactly the same location, with exactly the same conditions/light etc to try to exactly recreate that image, the exif is of little or no value to you.
On the contrary......
Anyway, this is turning into a witch hunt with name calling, and some are not understanding or reading my posts correctly, so I will desist from antagonising more people.
So...... you don't see YouTube instructional videos for specific cameras and genres? If you did, you will see it's about camera type, settings, lens, etc.... Yes composition is also very important, as is post processing.
For me it is helpful to know what equipment was used and what settings, lens type etc.
I could point you at lots of my own threads (I wouldn't victimise anyone else, it wouldn't be fair) where I post images, and alongside, there's a whole "blurb" of the thoughts behind it, perhaps hints to hidden messages, often the thread ends up going into details of how the set was built, the props were made or sourced, and even occasionally into a "pullback" showing the set and lighting rigging. I'd like to think that those threads gave more information to people wishing to get into that particular genre of work than a few numbers on the camera and lens did...
Yes yes, you keep saying this, whilst not explaining how it is helpful.
Unless you're planning an identical image, it's no more useful than directions to a place you're not going.
Birds for example (although the OP has not mentioned it) but I look for the info.
I don't think that answers the 'how is it helpful' question.Birds for example (although the OP has not mentioned it) but I look for the info.
And his avatar photo :-( I should clean the spectacles.Except perhaps in his signature line![]()
Hardware information only...I don't think that answers the 'how is it helpful' question.![]()
The Flickr quote is only marketing blurb.Look, I am not going to be drawn into a very silly discussion on how useful EXIF data is when you are trying to improve your photography, it is obvious.
I am not the only one to think this. There are many sites that state that, to improve your technique and skill, look at other people's EXIF data.
Quote from one such site:
"Flickr is, in general, a great resource for beginning photographers because it allows you to look at literally millions of different photographs and photography styles. One of the best ways we learn is by example, and what could be better than millions of different examples, both good and bad? But there's a bonus - each one of those images includes EXIF data (when available). Which means if you're wondering how the heck the photographer got such a cool shot, all that data is right there for your perusal. Examining this data for every shot that impresses you (and even some that don't) is going to give you a ton of insight into how different camera settings can affect the characteristics of a photograph."
http://www.digital-photo-secrets.com/tip/4079/exif-improve-your-shot/
So..... I am not alone in thinking this.
Perhaps you can write to authors on sites who have this opinion and start brow beating them into submission, for stating the obvious.
I am not the only one to think this. There are many sites that state, to improve your technique and skill, look at other people's EXIF data.
If you're responding to other peoples posts it helps to:Well I wondered how this post was going to be twisted and hey, it's Flickr marketing blurb, you have to laugh......
"Other people's EXIF
I mentioned earlier how checking the EXIF of your images can help you improve your photography. Well, checking the EXIF of other people's images can also help you improve.
When you see an image you particularly like (or maybe don't like!) then you can check the EXIF to see how the photo was shot. Now, this won't give you the full story on how a photograph was created. But it can still give you some helpful pointers.
You can see the information such as the focal length (or maybe the lens) used, the shutter and aperture settings. This can give you at least some idea of the settings to use to create a photo in a similar style."
http://www.discoverdigitalphotography.com/2014/what-is-exif-how-is-it-useful/
Want more?
No one said EXIF is 'useless', for instance I used it just this morning when I had to find 2 images with matching EXIF to show in this threadMy perspective on this is positive, add information to help others where possible. That was my opening post. Some people on here have a negative perspective, keep EXIF information from learners and deem that information useless to the learning experience.
I think my positive perspective on publishing EXIF data is more helpful than condemning it as useless, a view that other professional photographers evidently don't share when it comes to teaching others. If the data is so useless, why is so much of it there in the first place, write to the manufacturers and tell them this data doesn't help anyone, perhaps they will remove it.
If you think studying EXIF will help; Knock y'self out, but don't believe you have a right to lecture the rest of the world that you've somehow discovered some holy grail they weren't aware of and that they're spoiling your learning by uploading using the wrong settings.
Awgydawg, you should really be a bit more precise as to that is the help you believe you would get. Maybe give examples. Keeping the discussion as is you will get the argument that Exif data are, are not, useful. To be fully honest they would be certainly useful to a burglar if they also had your address and you had some expensive kit.
How does it help you and how is it useful. I'd genuinely like to know.
I have taught many things, I am born teacher, so I am open and want to share my knowledge so that others can improve.
Already been there and done this, see the links to other sites, they will explain it.
I'm sorry, I must be very thick because it ISN'T obvious to me. I can, on the other hand, think of several reasons why it would be detrimental to development as a photographer to have access to it. So..
would you like to use your abilities as a born teacher, and your desire to share your knowledge to help me improve by understanding exactly what it is that makes exif data useful, since I can't see it.
Thanks, they're really notThanks for your comments Phil, you take some great photos bye the way.
This is just my opinion, EXIF really does help me and others it seems. I think you are so advanced, by the quality of your photos, that you may have forgotten how difficult it is, when starting out, after many years in my case. All data is useful to me.
But people want to know why you think exif data helps when learning. After all, you started this thread!People were stating that EXIF was useless for learning about photography and wanted me to argue the point. I just don't see the point in arguing about the obvious, so I linked to a couple (of many) sites that state that inspecting other people's EXIF data does help when learning. I did this rather than waste my time.
But people want to know why you think exif data helps when learning. After all, you started this thread!![]()
Do a Google search or look at the links I have published, I will not be drawn.
No. I meant you, linking to another site isn't going to help anyone understand what you hope to learn from exif data. Until we know that we're going to go around in circles.Already been there and done this, see the links to other sites, they will explain it.
