Cheers, didn't realise that was the term! lol
I can't really be bothered with all that thermal paste malarky and a little unsure about all the various cables that plug into the motherboard from the PSU etc. The rest of the components I already have in my current system so will transfer them over.
Will check out the links![]()
I'm looking at getting a completely silent computer at the moment using a Streacom FC8 EVO case although I may choose in the end to stick a very quiet 80mm fan in and go for the FC7
Add in an i5-3570k processor, 16GB of RAM, an ITX motherboard and a 128GB Crucial M4 SSD and probably a 3.5" storage drive and I'm looking at around £600 for a totally silent but powerful computer but with much less space. Have a look here for someone who did something similar.
I currently have a Midi tower with a full ATX system in and just find it a waste of space, even though I have plenty of space.
I've done a couple of microATX builds before and they can be a pain. I'm hoping with a picoPSU and using 15cm SATA cables it should make it a little easier.
It's not too difficult if you don't intend on touching the machine after you built it though.
that would yes, its the ATX power supplies and length of cables that are the bulk of the issue most of the time.
true.. i have upgrade-itis though![]()
Hmm.. small, passively cooled Ivy-Bridge machine. Do I need it? No. Do I want it............
Cheers for the replies.
After a bit of research I spec'd up this:
Case: CoolerMaster Elite 430 @ £37.98
PSU: Thermaltake Smart Power 650w modular @ £81.98
Motherboard: MSI Z77A-G41 Intel Z77 (Socket 1155) @ £69.98
Processor: 3rd Gen Intel Core i7 3770 3.4GHz Sock LGA1155 (RETAIL) @ £242.99
Memory: Crucial Ballistix Sport 8GB DDR3 PC3-10600 C9 1333MHz £38.99
Total Price excluding the vodka and tonic: £393.26
The barebones one I linked to was net £324.99 for
•Intel Core i5 3570K Processor
•2 x 4GB DDR3 1333Mhz Memory
•Novatech Gaming Tower Case
•Novatech PowerStation Production 500W PSU
•Intel Z77 Express Chipset
I don't know the brand of the memory or motherboard in the barebones one although I'm assuming it's their own brand so I'm thinking for the sake of an extra £70 I can get a much better processor, branded Ram, decent PSU? and a fairly decent motherboard? Hope I'm not missing anything here?
Then I'll need an SSD but the rest I'm pulling from my current system. Although there's nothing wrong with my current system it is getting a little old now especially in the hard drive area so I'm wondering if £393 + SSD and the hassle of building it is worth it or not?
gman said:Cheers for the replies.
Only thing I'd say is you might want to say what else you are putting in it from your current system, just to make sure everything is compatible (I'm sure it is).
I'd be looking at at least 12 gigs of ram on that top self build mate. 8 gigs is the weak link there.
the MSI Z77A-G41 being dual channel you may as well get 16gb for a few extra quid
The memory system has 2 channels so it can read 2 memory devices at once. This is why you buy 2 memory DIMMs at a time - one for each channel. To get 12G you need 2 x 4G paired and 2 x 2G paired. The cost differential is minimal between 2x 4G and 2 x 2G so if you are going to get 4 DIMMs you might asw well get 4 x 4G.When you say Dual Channel, I'm a little lost?
Nice one, thanks for explaining. 12GB it is!
Sorry, I meant 16GB. Head up my arse this morning from destroyed sleep pattern![]()
