- Doug
In theory if you had a decent ammount of controllability then yes probably - and if you did the air inside and the wing plan would probably keep it afloat long enough to get people off - however if your plane was fully functional you wouldn't be landing on water anyway - whether you could get a damaged plane with serious faults down safely would probably be another matter - the hudson river pilot did, but he was relatively low and slow at the time - getting a badly damaged tripple 7 down from altitude and pulling off a safe landing would be miraculous, you'd be much more likely to break up or depart controlled flight and spin in, or to cartwheel when you hit the water which would leave debris.
The question of why they havent found debris is more likely answered by the sea being a very big place, and the debris not staying afloat that long - what has happened to the black box is another question
The flight data recorder is designed to send out a homing signal once per second from depths up to 20,000 ft for 30 days. It is audible on sonar but only from a few miles therefore searchers would need to get quite near before hearing it.
Sorry duplicate post.
