If I was driving a petrol, not diesel Passat my fuel would cost me like a couple thousand more per year. This is not an exaggeration, and my site proves it
LPG conversion would be the only thing that could save the bank after the initial cost of nearly £2k.
4 cylinder petrols tend to feel very low in low end power vs diesels unless they are some bigger turbo sport versions, or at least a good V6. I reckon I will just go straight to electric / electric-hybrid when the time is right, maybe in 5 years time.
I have done a search on this forum already, a lot of stuff on Diesels but not found anything specific about the pros and cons of getting a Diesel. We have had two diesel cars over the last few years, and about to replace it with another. When we first used Diesel years ago it was cheaper, but now the fuel is more expensive than Petrol plus we always get filthy hands at the pumps. Plus there is always talk of phasing Diesel vehicles out, so it seems it is not so popular any more..
Wonder if we should go petrol, may save money in the long run
1. Petrol and diesel costs about the same right now in most pumps. Diesel is usually 1p less. In most of Europe diesel costs quite a bit less.
2.
Almost all pumps provide disposable gloves. It is rather unwise not to use them. Petrol is not much better for the skin (a carcinogen before you even consider all super harmful additives in the premium version)
3. Diesels are not going anywhere in the next 3 years, unless you live in London. If so you'd be wise to get electric/hybrid or at the very least brand new Euro VI diesel - combating congestion charge being the prime reason.
Due to Russ's points about DPF's and DMF's, after years of owning a diesel I'd now go back to petrol I think.
DPFs problems vary greatly across different cars. It is best to do research and buy the more reliable ones.
DMF is likely to go in any car between 90-150k. You then replace it with single mass kit, or even better you buy an auto and never have to worry about the stupid thing and the stupid manual transmission (there is a flywheel in dual clutch autos... buy one that doesn't rattle!)
PD140 is well known for DMF failures too.
Horrible engines; all late VAG PDs including the last 1.9TDI (BXE) are seriously temperamental. The later (58+, the ones affected by scandal) Common Rail engines are far superior
It is however comforting to know that most VAG engines come in rather cheap from scraps and there is a plentiful supply should the worst happen. In comparison try finding an affordable Range Rover, Jag or even a Mazda unit. They don't exist.
