Naboo32
- Andy
I've spent countless hours in the last three days, trawling around the Internet trying to answer a very basic question, but with absolutely no luck whatsoever
Basically, I am thinking about getting into developing my own (b&w) film, with a view to getting high quality digital scans (roughly on par with the output from a DSLR, in terms of print-able size) to either print or display on a large monitor.
The question is: Which dedicated 35mm negative scanner is capable of doing this :shrug:?
Before I can make that decision, I need to know exactly what kind of results I could expect from whichever scanner I choose. If the image quality is not acceptable, then I can forget about shooting any more film and just go back to the boring world of DSLRs :|.
What is making this decision next to impossible is that every single thread and article that I have managed to Google up has consisted of either; a). nothing but these little black things, called 'words' :bonk: or, b). example scans made with desktop flat-bed scanners (and mostly in threads where the posters are complaining about lack of image quality :shrug
So, what I'm asking ... no, begging you for here, is to please post some example scans of (preferably b&w) 35mm negatives made with a purpose-built negative scanner.
As well as that, I would need to know which make and model of scanner was used, which type of film (or just ISO/ASA value, if that's all that is known) it was and any other relevant info about the developing or scanning process (i.e. were the negs developed professionally, did you have to add a lot of tweaks to the 'raw' scan? etc.).
Instead of trying to ask questions about what I want from a scanner, just seeing the results will be enough to enable me to decide whether or not to carrying on my experiments with film. I'm sure that you understand
. Thanks in advance for any constructive input
Andy
Andy
