Box Brownie
- No
Hi all
My other half's sister has an issue or two with her 02 plated Focus.
1) the ignition key barrel apparently no longer has the first click step, turning the key immediately engages the starter and it starts OK. The independent garage she uses told her it is not a simple job to just swap out the barrel and said they have dismantled and and tried their best to 'repair it' but it is no better. In regard to swapping it out and replacing they told her along the lines "not that simple as changing that means making changes to other parts that it is connected to...." Does that make sense or are they pulling the wool over eyes!
2) She reported a loss of power most noticable for example when pulling away in right hand turn................all they said they did was replace the spark plugs but again not 100% clear if sorted out OK?
Any insights or thoughts welcome?
