Bobsyeruncle
- Bob
Thanks.I'm sure you could easily make shims to space the holders out if required. A soda can used to be made from aluminum about .3mm thick (probably thinner these days). Just layers of tape would probably do it.
Quite possibly... .3mm isn't much.Thanks.
I'm thinking if I loosen the screws on the holder I might be able to squeeze in the 2.3mm filter instead of the 2mm filters without needing shims?
