Fast boiling kettles
tonyq
Please can anyone tell me what is classed as a "Fast boiling kettle" is it just by the wattage eg 3000w for the kettle?
Can anyone recommend a reasonably priced fast boiling kettle.
Is it something like this you want? http://www.amazon.co.uk/Breville-VKJ142-Hot-Cup/dp/B001L5SSGQ/ref=sr_1_1?s=kitchen&ie=UTF8&qid=1400407810&sr=1-1&keywords=instant hot water
They work 'faster' by only boiling the water as it passes through the heating element on the way to the spout I think.
It actually has a main reservoir and small heating tank (cupfull, but the quantity heated is user variable by a small amount).
I had one of those. Note that they call it a "hot water dispenser" which is OK for coffee. I did not think it made good tea because the water was not boiling.
Our fast boil kettle doesn't have an element that sits in the water like a "normal kettle", the bottom of the kettle is a flat disc - I presume the element is under this and potentially in contact with it so you have a larger surface area for boiling the water...
Another thing we noticed, apart from the fact they are much quicker to boil the water, they are noisier - not a problem now, but was a bit of a surprise how noisier it was initially....
Got this one
http://www.cuisinart.co.uk/multi-temp-jug-kettle.html
say site fast boiling in description and in use it's pretty quick
But keep the receipt.
Both my Cuisinart devices (this kettle and a toaster) failed within a couple of years. Still well under the 5 year warranty but I'd lost the receipts :( Replaced them both with the same models as I couldn't find anything else I liked as much for the money.
For people with more money than sense - and although I may not have much sense, I would have to have a whole lot more money before I'd spend that sort of money on a kettle!
How long does a 'fast boiling kettle' take to bring 1 litre of water to the boil, compared with a cheap kettle from a supermarket? I'm just curious...............
If anyone's going to have a go, please include a microwave in the equasion, seeing as heating water is "what they do" :-)
I don't care.
I boils water....end of.
