calling all Tokina 12-24 users
ricky1980
Richard Wong
I have been using this lens this afternoon. and now i have uploaded the pictures into lightroom, This lens has some serious amount of vignetting at 12mm (maybe not helped by my UV filter) even at f22 the vignetting is still visible, and the usable range starts around 16mm.
Additionally the problem seems to get worse under bad light. I got 2 shots both with 12mm settings and f11. One is in a fair decent light with ISO800 and 1/60, the other one is getting pretty dark even with ISO 2400 i needed 1/40. its the 1/40 that showed vignetting while the other didn't.
The vignetting is not very obvious as i couldn't detect it on the LCD but it's blatant enough for me to notice it on the screen later on.
I will post some pictures later, but do you have similar issues?
I know maybe i shouldn't be using the 12mm, but it saves me walking a few steps (actually quite a lot of steps) also it catches really nice wide range of things.
shooting in snow fall is hard, have no idea of ways to keep the snow flakes off the lens.
Take the filter off.
I never noticed any vignetting issue with the 12-24.
Also make sure the hood is fitted correctly.
No vignetting on mine either with a filter on at 12mm. I took some shots today with it in fact at 12mm plus uv on.
i think it is the filter. cos i noticed the one i said without vignette, has in fact got vignette.
it's slight blue/green in tint, can't even corrected in RAW. only hope is to convert the picture to monochrome...
but i think this picture would work in a bit of vignette, but i got a stitching with vignette in the middle...gah!!!
I think i will take that filter off
it definitely vignettes at 12mm without the filter. just chked very quickly against a bright wall. at 15mm there is no issues.
DO you think its a lens problem? the reviews all shown some serious vignette but at f5.6 or f8 the problem is gone.
just ran a few shots with flash, it doesn't vignette with flash.
hmmm...
