Sigma 70-300 AF gears are made from plastic. I've been using Sigma lenses for donkeys years without issue (except whe I put the 70-300 on my A700 in fast AF mode) and had it repaired. Sigma (UK) said "use in slow AF mode". Something about shutting the barn door after the horse had bolted came to mind and a £100.000 repair bill in the process.Hi people, was told about this thread and just thought id ask a question....just wanted to find out off any Sony DSLR users if they use Sigma lenses and if they are ok on them.
The reason i ask this is because of the fault that became apparent on the Sigma 70-300 F4-5.6 and the gears stripping.
just wondered if any of the other Sigma lenses have the same problems as i am looking at some new ones.
Thanks in advance
If you want a dedicated Sony mount ringflash, get the re-branded Marumi (Delta DRF-14 S) from Foto-Tip via eBay. Does what it says on the tin at silly money. Take a look at item: 350311920117 for example.Hi folks,
I am thinking of buying a ring flash for macro and I saw the MINOLTA MAXXUM MACRO1200 AF RING FLASH FOR SONY/MINOLTA on ebay current bid £19.99 and would appreciate if anyone could give me any information on the item. Has anyone used it ,will it fit the a330 and what size of lenses does it take, as there is little information on the sellers site? Any information would be much appreciated.
Thanks,
Melmount.
I'm not a flashgun/lighting guru, but I did come across the Cactus wireless triggers, though I have no idea if they're any good etc.hi guys...okay,i want to use my HVF-L42M flashgun off camera,but don't want to use the pop up flash to fire it,so as i understand it,i will need a flash sync cord to do this,yeah? Also,the 42 doesn't have a terminal[?]to connect the cord to,but i've recently purchased an hotshoe adapter[HS1100 i think]which has a terminal for the sync cord,so could i connect the cord to this,and mount the flash on top allowing it to work?
hope this all makes sense...![]()
Personally I would sell both and get a Minolta AF 70-210mm F4 'Beercan'.Talking of 70-300 sigmas, im not sure whether to sell mine or my 70-210mm minolta.
Which one of these would you keep? Both have their merits as a cheap zoom.
http://www.dyxum.com/lenses/Sigma-70-300-F4-5.6-DL-Macro_lens419.html
http://www.dyxum.com/lenses/Minolta-AF-70-210-F3.5-4.5_lens49.html
Anything on here of any use stan
http://support.sony-europe.com/dime/crl/dslr/dslr.aspx?site=odw_en_GB&m=DSLR-A700
I'm guessing you're using 64 bit, if not use the link below
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&f=sids_win2&m=DSLR-A700
Click start button then right click 'computer' and select properties, it will show what version
IDC runs fine on Windows 7 Home Premium 64-bit for me ...
pretty sure that I used a later version to install though than the A700 disc.
Well I have a USA spec one advertised on TP if that helps. http://www.talkphotography.co.uk/forums/showthread.php?t=327613Or if you don't mind second hand, the A700. It doesn't have as many megapixels or video though, if those things are important to you, but is very good for still photos. Plus you should be able to get a good one for under £400 nowadays.
I got a quick flash question, im using an on camera flash and if i set it to ADI and the lens isnt capable of supporting ADI does it automaticaly switch to TTL?
How can you actually tell if a lens supports ADI as you seem to always be able to select it?
Granted ive only used it on my sigma 17-70 but even boucing the flash i can select ADI which surely should be disabled in bouncing yeah?
Thanks.
Thanks Jonathan, much appreciated it.
Better to leave it on ADI rather than TTL? Seem to get more consistant exposure with ADI, but then ive not used the flash a massive amount as i only got it this week.![]()
I'm so excited I just had to tell someone! I just ordered my new Sony 50mm 1.8! I can't wait for it to come! It is supposed to get here day-after-tomorrow so hopefully I'll get some pictures posted.![]()
While we're on the subject of "easy choice" lenses....
Jessops currently have the 85/2.8 for £99. In-store only and stocks are very limited. Argos also have all 3 EC lenses on offer, plus good prices for the 30/2.8 macro and 28/2.8.
stan the man said:do you have a link to the 85/2.8 please john?
