Birds in flight....best settings on D7000?
Bobsyeruncle
Bob
looking to have a go at birds in flight with my D7000 and sigma 150-600mm C lens.
Just looking for some hints and tips regarding the best settings to use, that can then be saved in the U1 or U2 section. :)
presumably with big birds - small ones are impossible
AF-C
9 points ........ or the nearest the D7000 gives you
start at 1/1000th sec
pan
+EV 1,0 +........ or whatever depending on the bg ......... you are likely to under expose if anything
Start with something simple,gulls normally play ball and set about 300mm until you start getting a feel for it.
