srichards
- Suz
Does anyone else have an appletv 3 from which they stream music via itunes match using the ipad 'remote' app and not from mac shared library for any length of time? I'm finding it is a bit hit and miss even though it is on an Ethernet connection rather than wireless.
I have noticed that the drop outs and crash seem to be around the time that the sleep function is set for. eg if it is set on sleep after 5 hours of inactivity it will roughly lock up on 5 hours. This is of course daft as it is actively streaming! I set it for 10 hours and I'm pretty sure it was working fine for a 10 hour period where it was being used on and off then suddenly it wasn't then it locked then crashed. Only way to get it back is to pull the power lead and let it restart.
There are also other people that think that the choice of screensaver can be critical in how it behaves.
Setting it to sleep 'never' and manually sending it to sleep seems like the only sensible next step unless there is an obvious other cause for it.
