Yo.......PapaLazarou
fracster
I love BRASH and BRASH loves me
Ade
Ok, even though I said I don`t do them, I have been beaten into submission by Mrs Frac to photograph our nephews wedding on Saturday............:bang:
Been to the church, not buying new lenses for it, so will make do with my 17-55 F2.8,105 F2.8 and 180 F2.8.
The question I need answering, if you don`t mind and please be forthright,i`m not sensitive.I have one flash, a Nikon SB600, I figured on using it with a flexicord, it has a built in diffuser, will that diffuser be enough or should I put a hankie on it or buy a diffuser?
Thanks in advance.
And yes, the little git *thinks* he is getting it for free, how wrong he is.........:bat:
Well good look with the wedding, I would get yourself a stofen they do work well.
I never use my flash built in diffuser, they just dont work the same as a stofen. You might need to give your flash a + 1 exposure compensation for inside shots with it. Out side for fill flash you should be ok without the exposure compensation. The instructions say use it pointed up at 45 degrees, I have found that indoors this works well, but fill flash is better pointed at the subject.
http://www.stofen.com/FAQ/index.htm
Thanks........:thumbs:
Dumping the 180 for my 50 F1.8 as well.
