Cheers. Can you hook up to the drive from the camera and save images as they're being taken? Can I change the drive inside rather than rely on it to work until it is full then have to replace the whole thing?I use a 2Tb one of these on the road.
http://www.wdc.com/en/products/products.aspx?id=1330
Nexto among others do a range of photo banks:Are there any alternatives for cf cards?
Ive not used the wifi feature for transfers so not sure if it only does JPG. Be a bummer if it did as I shoot RAW. I guess a SD slot-backup mechanism is better than nothing! Thanks everyoneWe're you wanting to back up the sd card manually or to do it over WiFi? As I maybe wrong but I did read the 6D only transmits small size jpegs over WiFi. Sure I'll be corrected if that's not the case.
Ive not used the wifi feature for transfers so not sure if it only does JPG. Be a bummer if it did as I shoot RAW. I guess a SD slot-backup mechanism is better than nothing! Thanks everyone![]()
