Just a lot neater,less cables.Apart from having one box instead of two, is there any advantage in not using the supplied modem?
I do have an open reach modem,i just want it all tidyASUS DSL-AC68U and the Draytek 2860AC are the only 2 models which spring to mind, not a fan of tp-link or Netgear but I'm sure they have options too.
Removing the VDSL requirement will open your options considerably, assuming you have an openreach modem?
+1Also, I wouldn't let a two-year-old report put you off Asus routers. Asus is constantly updating the firmware and the problem was specific to using a USB drive on the router so easily avoided.
