What will I put it my studio space?
rbrown74
Rick
OK. I'm converting the back part of a 30x20" metal workshop into a studio. i still need space for a car to come in the front garage door but there is a door half way down the left hand side looking into it.
This leaves me a space of 20"x 18" approx. A full 20" backwall to use and one side of about 18" - I need a changing area and a sofa or a chair or two for people to use when spectating!
Would a heavy curtain be sufficient to partition the 'garage' area from the studio or should I go the whole hog and sheet it?
Most importantly - what way would you use the back wall? What colour would you paint it - Infinity curve? Would like to leave one corner with enough space for a different look - any suggestions?
I mainly do family work but also a quite a few young ladies for semi-model shoots so I like to play around with lights and really want a grey background to use with gels as well as the white and black. Currently have a 3 light Lencarta kit.
Any pics of current studio set-ups woudl be a great help! All suggestions appreciated!
A decent infinity curve will take up about 4m - which is most of your space - you can manage with less but I really wouldn't advise it, so my advice on this one is that the space probably isn't ideal for an infinity curve.
'Something different' could be small areas in brick, graffiti, a door, that sort of thing. texture is important, so rough plaster and rough brickwork tends to work well.
As for whether you need a solid partition or a curtain, that's just down to how much you want to spend against the importance of a professional image - only you can answer that one:)
Some good help there many thanks Garry.
The main wall - should I paint it grey and then have roll down white and black backdrops?
The perfect studio, in terms of lighting control, has a matt black ceiling and walls. But the public won't like it, so compromise is normally needed. Grey is a good compromise for the walls, but you can also use white as long as you are able to fully cover it with black drapes.
What would your choice be for the main wall for shooting against? - is it wise to try and use a painted surface or best to always use backdrops? Going for vinyl I reckon.
Just a concrete floor at the minute too so not sure what to cover it with either - this could get pricey! :D
