Also, just to add as ive been wondering this, whats the weatherproofing like on the D300, can it withstand being in torrential rainfall. I am pretty sure the D3 can, but wonder if the D300 is up to the same standard?
Generally speaking if a manufacturer deems a camera to be weatherproof, it means it should be able withstand being used in torrential rain. Don't go snorkeling with it though.
Just bear in mind that the lens needs to be weatherproof too -not all lenses are... so check that out. Also weather proof lenses usually need to have a filter fitted to prevent water getting past the front lens element and complete the sealing.
Some super tele lenses, whilst being weather sealed, have a front element far too big to fit a filter, and usually these lenses are fitted with a deeper than usual lenshood to protect the front element as much as possible.
Well considering i got a digital compact, i accidentally left it out in my garden Friday afternoon to meet up with some friends, while i was out it started throwing it down with rain + hail well when i got back i was like s#@% my camera. Ran out to the back grabbed it dried it off, i turned it on and it worked so i don't know whether that's just luck (which i never have) or the build of it!
Moisture penetration is usually rated as an IPxx number. See if your camera has an IP rating and then google it. It should be at least IP45, and mostly likely higher.
