- Brian
I was playing with the Minolta X-300 and at the same time comparing zooms and primes for keepers...all was going well when the ASA dial came loose and a few shots were at 3200 asa
erm the threaded plastic disc wasn't done up tight that holds the asa disc in place, so every time I wound on the film it was unscrewing the threaded plastic disc. :thumbsdown:.
Anyway I had to go back to the same spot the next day to redo some shots, well one day was sunny and the other was bright cloud and it shows in these shots of same, an similar lenses..all dev and low scan from Asda, Reala film, all lenses at f8.
I dunno if anyone is going to learn anything from this but I've got time to waste
Ensinor 24mm sunny:-
Ensinor 24mm bright cloud:-
Minolta 58mm f1.4 sunny:-
Minolta 50mm f1.7 bright cloud:-
