FishyFish
- Nige
- No
I picked up three 35mm compacts at the camera fair last week - an Olympus Superzoom 105, a Minolta Hi-Matic G2, and a Konica Pop. I've already fired off some shots with the Olympus, and the Minolta appears to work ok. The Konica, however, contained two leaking batteries, and despite my efforts to clean the terminals, there's still corrosion present and the camera won't power up with fresh batteries.
However, after a bit of Googling, I reckon I can still give it a go...
The camera has a single 1/125 shutter speed, is fixed focus, and has four aperture settings (f/4, f/8, f/11 & f/16). The aperture is set, oddly, by altering the ASA setting - 400ASA gives f/16, 200ASA gives f/11, 100ASA gives f/8, and forcing the flash up (even without power) gives f/4. I've checked this by opening the back and confirmed the different visible aperture at each setting. Given this, if I put some 100ASA film in there, and with the fixed shutter speed, I should be able to roughly shoot using Sunny 16 rules.
I just need to try and find out what the minimum focussing distance is, and then I'm good to go.
The camera cost me two quid, so it's gotta be worth a whirl, eh?
I'll either post some pics or moan about my failure in due course...
EDIT: My thousandth post!
