Vanguard Alta Pro 284CB
stu.artd
Stuart
The cheapest I can find the Alta Pro 284CT is £314.99 at Premier Ink. It's £349.99 at wex
However Amazon are offering the 284CT tripod along with the sbh-100 ballhead (the bundle is called the 284CB and the ballhead comes fitted to the tripod) for £286.73! The ballhead is usually around £65 and upwards from what I've seen.
is that better tripod leg than manfrotto 055 ?
I haven't used a Manfrotto 055 so can't comment on which is better, however the Vanguard is more versatile as the centre column can move through 180 degrees rather than just vertical or horizontal.
ok cheers.....
