- Asha
If I understand correctly the SB 800 flash gun in A (Auto) mode will work with the FE without any issues presuming I set the flash to match the camera settings for example:
50mm (focal length)
F/5.6
ISO 200
These paricualr settings offer a usable flash working range of 1 meter - 11 meters ( according to the info on the lcd screen)
My questions are.....
1. Does this mean that anything shot between those distances will be exposed correctly purely by the flash gun determining the power of the flash output automatically?
2. How do I determine what shutter speed setting on the camera?
Am I right believing that if I set to A (Auto) mode on the camera body then presumably the flash will fire to capture the subject but the shutter will remain open at whatever speed the cameras meter dictates....possibly very slow at 1/8 or less
If I set the shutter speed manually, then what maximum speed can i use without having underexposed results??
Sorry if i come across as a bit dumb but I always find flash difficult to understand.
50mm (focal length)
F/5.6
ISO 200
