twhite87
- Tim
Hi Guys,
I'm after a bit of advice.
I'm moving into a shared office where the wireless internet is a bit sketchy so want to be able to plug into the wired internet.
I currently dock my Macbook pro into a vertical henge dock which has two thunderbolt connectors (Which I connect to two screens), and a single USB connector. I have this connected to a 7 port USB hub as I have lots of hard drives and other things connected.
My question is: Will a USB to ethernet adapter work if I plug this into the hub, or will this need to be plugged directly into the laptop, in which case how can I then connect all of my USB devices up if the port is taken by the ethernet adapter.
Hope this all makes sense and someone has an answer for me.
