sk66
- Steven
It really depends on what you are shooting... If you're using it for stability (i.e. slow subject/long distance/low SS) then I would definitely recommend the 3 series instead. If you are using an unlocked gimbal on top to track moving subjects, then you really need higher SS's and the tripod is only supporting the weight so you don't wear out... the 2 series would do the job. But I still can't see paying more for it...Have you (or anybody else) used the gitzo gt2532s for long lenses? It's £100 more than the better one that was linked to but also 500g less. I'm not the biggest built (5'7 and just under 10 stone) so the weight makes a difference to me, plus I travel with it and 500g saved in the hold is helpful. I'm happy to pay less and carry more if the linked tripod is much sturdier for the focal length I'm shooting at (500mm with 1.4tc on crop body) but since you said it's the head that makes the difference and I have a proper wimberley that's solid, i wondered if the lighter 2 series would suffice. I'm expecting the answer to be "no, go for the heavier one", but it's worth asking.
