Fairyrose
- No
Hi all,
I just tried a new tripod - SIRUI MT5-AK MyTrip Travel Tripod In Aluminium. Two things occurred to me and I would be grateful for any thoughts or shared experiences.
First, the ball head kept sliding ever so slightly down as if pulled by the weight of my lens. I was only using a 18-55 or 50-200 lens so nothing too heavy and surely that can’t be right. I had to fix the ball head a centimetre or so higher against the horizon and then gently fine-adjust it to be in the correct position.
Also, I found the four screw legs somewhat cumbersome to set up and fold down again. I ended up carrying the tripod around with me in its extended form.
Are clip legs better/ easier? Looking online there seem to be more screw- leg tripods than clip legs so there must be a reason for that?
Also would you go for theee leg extensions instead of four?
Thanks in advance.
Thanks in advance.
