Tripod case serial no?
Ravinder
Ravinder Bindra
Hi guys
I have a Manfrotto tripod case which I'm trying to sell as I never use it. I've had a couple of people ask me for th serial no but I can't find a serial no on it...? Has anyone else got one of these cases? Any idea how I can get this info? Many thanks.
Are they asking for the model number and just got mixed up?
Sounds more logical
Something like a case or bag won't have a serial number.
+1
PS also just maybe the prospective purchaser thinks that they are buying the tripod itself??? But even then I have no idea why the serial number would be relevant?
They want to check the serial no to see if the bag is padded or not and also the case size. I have since found it. It was very well hidden on the inside and I've now got the relevant info. Thanks.
That sounds like the model number is what they needed as that would allow you to search the product info to see if it's padded or not and it's length. I've just check the one I don't use much and the model number is on the outside at the top of the strap.
Well I learn something new every day. I would have thought that two similar bags delineated by padded or non padded would have (slightly?) different model numbers! A serial number is normally used to identify individual items of the same type such the serial number on your camera will be different to your neighbour with the same body.
Edit ~ I type too slowly - Rob addressed the same aspect ahead of me ;)
I think I just got muddled up and actually menat model no. The label was on the inside at the very bottom tucked in. Not very easy to see. Had to use a torch to read it! But, got it anyway. I never use the bag so just want rid.
