Kondwani
- John
I am planning a long haul trip where one stage will require a maximum weight of 8kg for cabin luggage. I guess many of you have had the same dilemma as to how to minimise weight yet take enough kit in the event of any issue with your main camera, which in my case will be a Canon 7D Mkii. (plus 100-400mm, 10-20mm, 16-300mm lenses, x1.4 converter)
I do have a Canon 50D which will use the same lenses but I would then need to take an additional set of batteries and battery charger and it is quite old.
Should I take the 50D (perhaps in hold luggage or sell the 50D to buy a decent Compact camera as the backup ? NB. Finances will not allow for a second 7D body unfortunately.
Cheers
Cheers
