realspeed
- Bazza
- No
Final check done today and I found the tyres were only 15lbs and should be 32lbs pressure. One front sidelight didn't work , the bulb had not made proper contact,so cleaned that up now ok. All other lights ok. Refixed the front light bracket.
A small wood bar at the back the retaining catches had rusted up so wire brush and 3 in 1 oil sorted that out. Last the Jockey wheel at the front, the handle bar was hard to turn so plenty of oil and winding it did the trick. it was jamed into its lowest position.
So now good to go up for sale
