Time lapse with a D50
Panzerbjorn
Lo all,
I'm taking some time lapse with my D50 and I was wondering if anyone had any tips for remote triggering the shutter every minute or so.
I've got the ML-L3 remote but it still requires me to push the button every minute.
I've found a couple of devices that can do it but they all cost about $150 and can only be bought from the states.
I was wondering if I could rig up a digital timer unit to fire the ML-L3 every minute but I wouldn't know how to go about it. I'm pretty handy with a soldering iron but all of my electronics knowledge came from GCSE Systems and Control (almost 6 years ago) and I've forgotten most of it.
Anyone done anything similar?
Cheers
Panzer
Cheers Jimmy I'll take a gander at that.
Someone on another forum just mentioned about Nikon Camera Control. I can't really afford it and at the moment I can't put my computer near the camera, just thought I would mention it if anyone was going to suggest it.
Panzer
Didn't someone say that Nikon's have an intervalometer built in?
Either way, if your ML-L3 has a 2.5mm jack socket on it then one of the timers I made will work fine. I'm about to put together another order for parts so let me know if this is of use to you. They're £15 delivered with a battery.
Thanks for the info Mark,
The ML-L3 uses an infra-red signal to trigger the shutter rather than a plug you can put in the actual camera. The D50 doesn't have a wired shutter release. However if the timer just fires a signal through the circuit I'm sure I could just bypass the button and use the signal to fire the ML-L3.
Panzer
Drop me a PM if you're still interested, definitely sounds achievable but I can't believe the D50 doesn't have a remote socket?!
uh......I use Nikon Capture Camera Control, it comes with Nikon Capture 4 and NX, you are ofcourse tethered to the pc, but thats what its for, let the pc control the camera:thumbs:
And may I say, its a blinding bit of software, I've no clue what anyone shooting studio regularly, uses instead..
Cheers mark and joxby for the input. Like I said in the OP I don't have a computer I can hook it up to just yet. Going to be a couple of weeks before I have the laptop and then there's the price of the software.
I bought myself a spare ML-L3 in case I break it and I've got a 'universal start/stop timer' which I'll put together tomorrow.
The only issue I can see is the contact on the ML-L3 is a bit odd:
I'm assuming I can just join the in/out from the timer to either end of the 'snake like' contact. Failing that I'll have to unscrew the pcb, flip it over and see if there's an obvious + and - that I can solder to, to bypass the switch completely.
Panzer
Just realised I've gone and bought the wrong circuit kit.
Can anyone confirm that I can use a 555 Astable Switch Kit:
• Provides a timed output pulse at regular intervals
• Adjustable pulse duration and cycle time
• Period from 1 second to over 1 minute/ pulse time from less than 0.5 seconds to over 5 seconds
• Single pole changeover relay rated at 24V 10A (not suitable for direct switching of mains voltages)
• Requires a 12V power supply
I'm assuming that the timed output pulse is enough to trigger the ML-L3. The kit I'm looking at triggers a buzzer/speaker but I don't see why the contacts can't be adapted to fit to the ML-L3.
Cheers
Panzer
It works by joe!
It starts out with these:
And these:
It starts going together like this:
And with a bit of this:
Ends up looking like this:
Then you attach it to the ML-L3 and it looks like this:
That's it. :D
I've now got a fully working adjustable time laps controller :D
Panzer
