Donnie
- Paul
- No
Right thought I'd start a specific thread on this issue as I need to decide what to do about a car rig boom. I have everything else.
I've read the other thread here from start to finish a couple of times to get information but after doing so bought 6 metres of aluminium pole which was 30mm with a 2mm wall and at 4m had a stupid bounce on it, then fitted a stabiliser t piece and strap but didnt help.
Im basically looking to get opinions on what my next step should be and as I see it there's a couple of options (not including shelling out a grand for a pro setup which is out of budget)
So,
1. Stick with round tube and go for wider tubing, either 1 and 7/8ths" (47.6mm) with a 3.3mm wall or 2" (50.8mm) with a 4.8mm wall
or
2. Square tubing 40mm x 40mm with a 3mm wall or even 50 x 50 by 3.25
or
3. a combination of either of the above and buy a 10-22 lens as Im currently using a 17-55, thus allowing a shorter pole with less bounce, though then using a closer shot at 10mm may cause unacceptable distortion, this is on a crop sensor (1.6)
So any thoughts would be appreciated to help me decide?
So,
or
or
