Those vinyl floors (barnwood, vintage wood)
CaelansMummy
Does anyone know where they can be purchased in the UK? There is one seller I know of and they charge a fortune! It's the same material as my PVC tablecloth which cost me £15 so if I can find someone who prints them then it may be cheaper that way! I'm mainly doing newborn shoots and the only floor I have at the moment is a small piece of (real) vinyl flooring in a pale wood which was all I could find locally!
Thanks Richard! They were the company I knew of. I just wanted to see if anyone knew of any others before I spalsh out on a bit of tablecloth :lol:
Thankyou Mank - have you used them before? I would need it to be around 6ft x 6ft if I can. I will have a look this evening when I get time to sit down!
Sorry if I'm being thick here - do you mean a square of vinyl flooring to use as a floor in your image?
You can get images printed on to vinyl that look like wooden flooring, wall paper etc... (the vinyl itself is quite thin, it looks like a tablecloth)
They are quite expensive for what they are in my opinion but they are easy to store and transport because they roll up.
I use 4x4' MDF boards and wallpaper them, but then I cant really transport them if I needed to. So I bought a few vinyl ones too! :D
I thought that's what you did Rob
Couldn't you just use a piece of vinyl flooring though? They roll....
You can use vinyl flooring but most of it looks crap IMO.
I have a couple of flat pack laminate flooring too! But it only cost me £5 in the clearance section of united carpets! :D Its always good to check the clearance sections as you can drop onto some bargins!!
More tagage!!
Guess what I'm building today....
Dean
