stevelmx5
- Steve
- No
That doesn't have Auto-ISO though![]()
You're right but if it did, it would still be a manual camera which I'd have to make a decision on what aperture/shutter speed to use :0)
Yes ... I don't think we're disagreeing ... but the point is that with digital (certainly on Nikon, no idea if Canon, etc are the same but I assume so); set it to Auto-ISO and Manual, and you have full control of shutter and aperture (within limits due to light levels and the range of ISO you feel gives good results) and the camera sets the exposure level automatically.You're right but if it did, it would still be a manual camera which I'd have to make a decision on what aperture/shutter speed to use :0)
So set 1/125th; f/2.8 and the camera sets ISO 140
Or set 1/1000th; f2.8 and the camera sets ISO 1100
Agree ... Auto or Green Square mode. Auto mode will take control of things like the built in flash as well ISO sensitivity, focus modes, metering mode, etc.We're definitely not disagreeing :0). My point was that the D800 doesn't have an 'Auto' setting. Cameras that do have Auto take all control off the photographer and act as a point and shoot that you have no decision over.
Program Auto is just like S or A really; but the default is the camera sets BOTH shutter and aperture. You can then "Shift" the exposure to increase shutter speed while opening the aperture further (or vice versa) though you are restricted so (for example) I just picked my camera up and P set 1/50th and f/1.8 with ISO set to 125. Because it had shifted the ISO from its default 100, the camera wouldn't let me shift the settings. Pointed out the window I could get 1/100 f/5; shifted to 1/50 f/5.6 or 1/125 f/4.5.Shooting with Program Auto just means that the photographer has the choice to change the aperture or shutter speed and the camera decides the other. Shooting in Manual means that the photographer had to choose both the Aperture and Shutter speed so have the option to massively over-expose or under-expose if they want (creative decision) and on some cameras, has the option to handover control of ISO to the camera to balance the third corner of the triangle.
Sorry was a typo, I did know thatHe is a SHE ... but apart from that thats exactly what I mean ...
Sorry to keep disagreeing with you but you're wrong, in program mode the camera DOES change aperture and shutter by itself as it would in any auto mode, and you can leave it as this. The only difference is that you CAN manually override it if you choose to, otherwise it acts as an auto camera. The real reason why it is not a true auto mode is that you have to select the AF mode and metering, as well as choose when to use flash, In full auto I believe all of these are fully automated. So you are right in that program is not FULL auto, but it certainly IS full auto in regards to exposure.We're definitely not disagreeing :0). My point was that the D800 doesn't have an 'Auto' setting. Cameras that do have Auto take all control off the photographer and act as a point and shoot that you have no decision over.
Shooting with Program Auto just means that the photographer has the choice to change the aperture or shutter speed and the camera decides the other. Shooting in Manual means that the photographer has to choose both the Aperture and Shutter speed so have the option to massively over-expose or under-expose if they want (creative decision) and on some cameras, has the option to handover control of ISO to the camera to balance the third corner of the triangle.
Exactly what I was referring to earlier
I assume you mean respectably rather than respectively ... so I would respectably add that what Nikon write there isn't the whole story - at least if it works the same on D800 as on the D750 - as you can still "Shift" the programmed settings (as I said above) to increase the shutter speed while opening the aperture (or vice versa). Its not full control, but in some situations its a good option as you'll never get a situation where you have set a too high shutter speed for the lens' widest aperture (for example).
I can't even begin to think why you'd ever use auto if you understand exposure, even for snap shots![]()
TBH I have the habit of returning the settings to 'default' before turning the camera off, so if I've used bracketing, HDR or anything like that I always turn them off. I'd honestly be more concerned about missing a shot due to the camera not focussing on the right part of the frame if I was using auto. Each to their own I guessSpeed, if grabbing shots as they happen! I leave all my multi-mode cameras on full auto as a default starting position, so I'm ready to grab the camera and blast away if necessary. I think this is a good habit to get into... as the Scout motto goes, be prepared!
Have you (or a photographer friend of yours) never made a pig's ear of some shots, or missed them completely, because the camera settings have been left where they were from the last time the camera was used (lens set to manual focus, or exposure comp left + or - 1.5 stops, or aperture set to f1.8 and the camera won't fire as it's run out of shutter speed... or the self timer setting left on for that 'nothing's going to happen now for 10 seconds' experience!)?Reset everything and leave it on full auto each time you've finished playing, and you'll rarely miss or louse up a 'grab shot'!
Ren Kockwell was talking about Program shift.
A little different from normal Program.
Dan, assuming you are still interested ... I'm guessing the Nikon 35mm is the DX version, if so it won't be great on FX (it will work but vignette badly) and as Steven has already said the Siggy is a DX lens too.Afternoon everyone
Firstly, I apologies if there is already a post on this. I thought I remembered seeing a pinned post about it previously but I cannot find it anywhere! Maybe I was imagining it...
Anyway, I've been working on my photography for a few years now, mainly automotive work for magazines. My bodies are low spec, quite old and although great for when I was starting out I feel it's now time to upgrade.
I'm thinking of going full frame however I'm still a little confused about where to start in deciding what to choose and what I need to consider when choosing.
One the main question I have is how I check if my lenses are compatible with a full frame camera? I currently have:
- Nikon 35mm f/1.8
- Sigma 10-20mm f/4-5.6
- Tamron SP AF 70-300 F/4-5.6 Di VC USD
The second question I have is does anyone have any suggestions on good "starter" full frame Nikon camera? I am by no means a professional so I am not looking for anything within that league. Just something newer and better than I currently have.
Sorry for the long post!
Kind regards,
Dan
As interesting as some of the debate hasn't been ...
The Tamron would work fine on FX, though it would appear "shorter" as you lose the crop.
Not sure what style of camera body you have, you only say the are old, if they are D100, D2, D200 type then going down the D700, D8xx route would be a fairly easy switch as the layouts are still similar. Likewise, if it is a D70, D60 type body going down the D6xx or D750 route would have similar layouts. In reality, whatever you choose in FX will give the opportunity for better IQ but then so would a much later DX body. tbh I'd avoid the D600 simply down to the oil issues, the D610 is generally fine (I've had both). The D750 rightly gets a lot of praise as does the D810. I was never a fan of the D700 as I never quite got on with it (me at fault, it is a fine camera) and if 12MP is ok for you then there are some good examples to be had. Likewise used D800 or D800e can be had for sensible money and these are outstanding imo.
To some the difference doesn't matter, it really depends on usage. Each has some pros and cons which only you can decide which matters more. The D800 will be more demanding on lenses than the D700 for example. The file sizes are much larger so your pc/mac may need an upgrade, but the upside of that is you get more data to work with!. The D800 uses newer technology too so has IQ improvements over the D700 - but that doesn't mean the D700 IQ is bad, far from it. Both are built well.Thank you to everyone who has replied, there are certainly plenty of things in here to look into and consider!
Hi Paul, thanks for your reply
I should have probably mentioned in my OP, I currently have a Nikon D3000 and a D5100.
The issue with the 35mm probably isn't too much of a problem as I'd be looking to swap that for a nifty fiftyI would however need to look for an alternative wide angle as I use my Sigma all the time when doing my rig shots, so that is something I would need to consider.
I've had a quick look at the D800 you mentioned and that looks exactly like the kind of thing I am looking for, as does D700 which I know others have suggested. I know there are other things to consider and not just the MP but I notice there is a big MP difference between the two. Do you know how much of a difference the extra MP would make compared with the D700?
Manual mode with auto ISO is an oxymoron.
Having control of 2/3 of the exposure triangle isn't 'manual' anything, its auto as the camera is fixing your exposure.
I appreciate it's a further diversion, but it's a bete noir
what a bete noirI had to look that word up Phil,i thought it was a moron from Oxford![]()
In simple terms MP only really matter if you plan on cropping heavily or printing very large. But even if printing large many would argue that 12mp is enough as in theory if the image is that large then viewing distance will be further.Thank you to everyone who has replied, there are certainly plenty of things in here to look into and consider!
I agree it's an oxymoron ... but it's very useful (IMO).Manual mode with auto ISO is an oxymoron.
Yes it's not "manual" in the truest sense, but you have complete control over the creative choices for shutter and aperture and can be confident of getting a good exposure. As @snerkler commented, it's good for wildlife where you want to ensure the shutter speed and aperture both stay static, but you still want correct exposure as you move from the light, to shadows and back again.
But don't you use the light meter to guide you to the 'correct' exposure anyway, or do you still base it on the sunny 16 rule? But in the example above you wouldn't have time to be constantly calculating exposure in your head and be changing ISO as you pan.It's not the 'correct' exposure though, it's the cameras guess at a correct exposure.
Whereas 'manual' ought to be the photographers guess at a correct exposure.
But don't you use the light meter to guide you to the 'correct' exposure anyway? But in the example above you wouldn't have time to be constantly calculating exposure in your head and be changing ISO as you pan.
Was she the one that used to make the hot pot in the Rover's Return pub in Coronation Street?what a bete noir![]()
No that was Dick Turpins sister BettyWas she the one that used to make the hot pot in the Rover's Return pub in Coronation Street?![]()
Oh.... so is she getting a full frame Nikon then?No that was Dick Turpins sister Betty![]()
Ah! The bitter words of a Canon owner, where auto ISO isn't really!Manual mode with auto ISO is an oxymoron.
One thing you haven't mentioned is why you want to go full frame.
If the answer (honestly) is, "because I want a sexier bit of kit that looks more pro and feels robust" then fine. No problems. At least you're being honest.
Otherwise, it's nigh on impossible to recommend something as we don't know why you want to upgrade to a new body and potentially have to replace a few - if not all - of your lenses. The 35mm and Sigma will both need to be used in FX only mode (so less benefit in switching bodies), not sure about the other one.
FWIW, I "upgraded" from a Pentax APS-C to a Nikon FF a year and a bit ago. I love my new camera and am delighted with the upgrade. Was it worth spending over £2.5k on new gear? Probably not, but I'm still pleased I did it. And if you think it's going to cost much less than £2k to get good new glass and a decent fairly modern FF body then make sure you've done your sums properly!
I prefer the whole FOV/bokeh thing with FF too. One thing I rarely see mentioned is the perspective. With FF and the same FL length you have to get closer with FF to frame the same as crop body. Not only does DOF reduce as you get closer but the perspective changes and you get less 'compression', i.e. the background looks further away from the subject.I can still remember the thrill of seeing my first photos from my D3 when I upgraded from D300. However I also bought good glass, Nikon 200-400 f4, in this case. I think to get the benefits from FF you will need good glass. The main benefit I get is low light ability. In good light the only benefit to me usually is the improvement in isolating the subject, but again fast glass is required.
It was just another example of the difference you get with sensor size, but unless I'm missing something crop never looks fully the same as FF when you're shooting with shallow DOF. If you want the same perspective/compression you have to be the same distance from the subject. On a crop body this means using a shorter focal length to get the same framing and the shorter focal length results in a larger DOF. So you can get same framing and same DOF, but resulting in different perspective/compression, or same framing and same perspective/compression but resulting different DOF.Erm, not really. ..Why would you change formats but use the same focal length? That's what the crop factor is all about. Anything you want to do with framing and perspective can be done just as easily with either format.
Afternoon everyone
- Nikon 35mm f/1.8
Kind regards,
Dan
I guess it boils down to preference and/or what you're used to. I started out with crop, and now have FF and m4/3. My personal preference is FF.
