The penny has finally dropped!
Cobra
In Memoriam. TPer Emeritus
Admin
The real Chris
Well the penny has finally dropped I tried a few shots in RAW
and the embedded editing RAW software in CS3 make life so much easier
But you lose a lot of definition when saving as a jpeg file.
The gif file has a lot more definition ( to my eyes) and the jpeg has a green cast, same picture just two differant save as commands
The other thing I am having trouble with, I downloaded the windows RAW file
viewer but it won't open the files in preview I get "failed to load the image":shrug:
Thanks for the help on my "RAW" thread guys:thumbs: Its early days yet but first impressions are good
Jpeg
Gif
Er, don't use gif. Use jpg.
# In view of the limitation on the GIF formation to 256 colors, JPEG is a more commonly used format for digital photographs. JPEGs can save information on more than 16 million different colors and use more aggressive, lossy compression which has a less noticeable effect on photographs than it does on images with sharp edges.
Thanks Pete but the top jpeg image look "worse" than the gif or is it just me? :shrug:
The jpg looks fine to me. Maybe its your monitor? What settings are you using to save jpgs? You really really really shouldn't use gif's.
The gif looks terrible :thinking:
Loss of texture, and its very noisy.
Once resized at around 600px I just use the highest setting that will alow me to post ie less than 150kb round about 8 or 9
Just hit the monitor with a peice of 4x2, I see what you mean now Alex, I think " someone" has been fiddling ( wanna buy a couple of teenagers?:D ) Cheers :thumbs:
:p :D
Any ideas as to why I can't get the windows raw viewer to open the files?
Maybe your RAW file from the camera is not supported
or you dont have
Micros*** .NET Framework version 1.1 or higher installed
or you dont have
Ok Thanks for that Its a 400D and I think that it is supported?
i'll check out the .Net framework thingy too
:thumbs:
Also check for an update as the 400D was not included in the original version of this software.
:thumbs: I am raking round right now
I take it your using Win XP Service Pack 2 or newer, as you cant view raw in older versions.
Yep XP Pro SP 2
The image data say's its a "_CR2" which is supported occording to the download options :shrug:
I can open other files JPEG etc in the raw veiwer but not raw I am not having a good day so far :D
if you go into advanced options for the viewer and make sure CR2 is ticked, after that its wait for the update from micros***, as i think there is more too it than just being a .cr2 file.
I ticked all the options just because I am greedy :D
Ok So I guess its wait then Cheers :thumbs:
you can always use bridge to view your RAW files, and as its integrated with CS3 very nicely its easy and quick to use.
Thanks for the info, I will give it a try. Its just that I am used to having preview thumbnails when I open a folder in windows, on my desktop, then choseing how to open the full size. But I guess I will have to get used to this, until good ole Billy Gates gets around to letting me do it my way
