Telephoto
londonsnapper
Hi there,
Just a quick question. Does 'telephoto' mean a zoom lens, or does it just mean a lens with a high magnification? For example, can a telephoto lens be a prime lens?
Thanks!
Thanks. Also, what's a standard focal length on a APS-C and Micro Four Thirds sensor? I know that it's around 30mm and 25mm respectively, but isn't that a completely different focal length that will change the depth perception rather than just compensate for the restricted field of view?
Telephoto is not applicable to zoom lenses.
Not true.
The word "telephoto" was originally "telephotographic". The first bit comes from the Greek "tele-", meaning distant (as in television, seeing at a distance). So in its simplest terms a telephoto lens is one that allows you to take photographs of distant objects. That means it's a lens with a long focal length, and it can be a telephoto prime or a telephoto zoom.
Not true.
I knew my reply didnt look right. I meant to say that it is not applicable to just zoom lenses. :bonk:
