By taping over three of the pins the body doesn't know that the T/C is present and hence it will still attempt AF. The downside to this is the risk of burning out the lens focus motor due to excessive hunting.
Bob if you tape the three pins and then shoot with MF selected on the lens instead of AF (By doing this you can still retain the focus signal when you half depress the shutter button as you are focussing manually whereas you don't get this signal if AF is selected), would you think that this has any detrimental effect on the AF motor in the lens.
