Switch off sound AF?
SnEm
Hi,
Does anyone know how I can switch off the sound of my AF?
I have a Sony A57, looked everywhere in the menu, can't find it???
Thanks!
SnEm
According to google the on/off option is in audio signals, set up menu 2.
Hi,
Thanks!
SnEm
Use manual focus. Your lens makes the noise.
Do you mean the AF confirmation beep , the noise of the lens itself focusing or both?
The AF confirmation beep should be in the menu.
For the noise of the lens focusing itself as twist says this is lens related. If you use a screw-driven lens this will be noisier than one with an in-lens motor & even then a SAM lens will be noisier than an SSM one.
You could also try using a plug in mic off camera rather than using the inbuilt.
