myotis
- Graham
- No
Graham, I loved C1, the end result was lovely. What I needed was a file ... longest edge 1500 pixels and file no bigger than 1.5MB. I did post on the C1 forum asking if it could be achieved but unfortunately I was told it couldn't be achieved.![]()
Well, my idea does seem to work, but maybe not perfectly enough for your needs.
1. Pre - setup the crop tool to take its cropping instructions from the output processing recipe
2. Pre- setup an output recipe to use a long dimension of 1500 pixels (and the other parameters needed e.g sRGB colour space, export destination etc)
4. set up a C1 session for the sports event (customise C1 interface to remove all tool tabs, not relevant to this task, save as template)
5. Drag images from PM to C1 icon
6. Select all images in C1 and use autocorrect option (use the Red, Green and Blue channel option for auto levels, and tweak shadow and highlight thresholds, this tends to cut through haze and give subtle lift to contrast)
7. Tweak images with sliders (if needed, I find the auto correct is very good)
3. crop the images, drop dimensions are shown on the crop lines, longer dimension is locked, shorter dimension changes as you change the crop, keep the shorter dimension under 1000 pixels.
4. crop all the images
5 select all the images.
6. Cmd/ctrl D to run process recipe.
7. Jpegs appear in folder defined in process recipe.
8. open folder in PM
The only issue I had was that because jpeg conversion size depends on the information in the raw, the jpegs varied in size, but in my (inadequate) trials I found that if I set the Jpeg quality to 95%, the images I exported all lay between 800kb and 1.4Mb. At 100% I ended up with images as large as 1.9Gb.
Does this sound workable for you? If you think it worthwhile pursuing, there are a couple of recent Capture One videos that might be useful:
1. rapid editing here
2 Output recipes here
and an older one on sessions (instead of catalogues, but you were probably already using sessions in C1) here
And of course you can always get back to me, but unless anyone else shows an interest in this, maybe by PM so we don't clutter up this thread.
