Stamdard or wide angle adapter?
ian-83
Ian
What type of adapter ring do I need for fitting a 100mm square filter kit to a Nikon 16-85mm lens on a crop sensor?
Do I need a regular or wide angle?
Just picked up a Hitech Corby Brown signature kit off Amazon for £85 New!
Regular one should be fine
Have a think about whether you might need a wide angle one in futur before deciding. I use thefilterdude and have been happy with rings they provide
Currently have only the 16-85mm, got some cheap Kood P size filters which vignettes below 19mm. I am guessing with 100mm on the same lens this should now be avoided.
If I get a wider lens, like the sigma 10-20mm I'll probably get the wide angle adapter
