topcatproduction
First post in this section I believe- slowly getting into the pp side of photography and realising it's potential.
I enjoy close up macro photography, but not being able to afford the MPE-65 I'm stuck with using a reversed 28mm prime on tubes for maximum magnification, the obvious problem with magnification of this level is the paper thin DOF. I've seen an example of a stacked image from many shots, can someone explain how I would do this?!
I know I will need a macro rail which I dont have yet, and I use cs3 but thats as much as I know!
