sk66
- Steven
Ah, I missed that... but given everything else, I'm not convinced.As I'm sure you know a lens is at its max aperture until the shot is taken, therefore if an f5.6 lens is stuck it will stay at f5.6 rather than stopping down to f22.
To check for this I suggested the OP take a pic of a close up subject (not filling the frame) and take a shot at f5.6 and f22 and see if the DOF changes. He came back saying it doesn't stop down so I assume the DOF didn't change.
The shot taken in aperture priority was "correct." And, as I'm sure you know, the exposure is calculated at max aperture based upon the aperture setting. The messed up shot was in manual... and the other settings explain it.
Peter, it's easy to visually determine if a Nikon lens's aperture is messed up. It will either be stuck/sticky, or the spring will be broken/disconnected. Both are fairly unlikely, but a quick flip of the aperture lever will tell (it should easily push open and spring back closed).
This is what it looks like on the 18-55.
