Spot healing tool technique
Stuart M
Stuart
A question for those of you that are clued up on using the spot healing tool. I appreciate that each circumstance is different but, generally speaking, if I wanted to erase a long thin thing such as a power line that stretches all the way across an image, would it be best to try and do the whole thing in one go or do short sections at a time depending on what's showing behind each area? Thanks for any suggestions.
Just try it if it doesn't work step back or delete and try another way.
A single patch is sometimes best but if its to big that it cannot find another area to take from then try smaller
Are you referring to Photoshop?
If so... the normal healing tool is best, as you can decide where to sample from.
I prefer to make selections from close to the area that has to be healed and do something like the removal of a telephone line removal in multiple steps . That way the software picks up very similar tones to the tones required for output. I'm not sure I've explained that very well but I hope you get my drift.
Rob
