cammiedh13
- Cam
- No
I do some mountain biking photography. I spent a weekend with Seb Rogers and he taught me a whole lot about it.
Shoot in manual. If the rider is going to be close to the camera you can use fill in flash. Pop up the flash and then under-expose by 2/3ds of a stop. That should help balance out the image. That way you should be able to freeze the action (use a shutter speed of 1/100th or above - below this it can get a bit blurry). Also - follow the rider keep him in the correct position in the frame and move your camera to keep him in that position - then at the opportune moment - take the photo. If the rider is far away, then flash wont be much good - you've got to pan with the rider. Shutter speeds of 1/60th will be difficult - keep it higher than that. But you really dont need a super high shutter speed - honest.
A key part of getting a shot is to get the rider to look like he or she is riding fast, but for them to be going quite slow and steady - that way you are more likely to be able to pan and to get the timing right.
When you follow someone on camera wouldnt they end up out of focus ? And can someone explain what you mean by pan the rider
