Fatheadedlizard
- Alan
But perhaps not everyone else does.![]()
I had an Elinchrom D-Lite 2 kits for years (well 2 of them actually) worked fine - modifiers cost a fortune though
If I was buying again - Lencarta - and yes as Phil says, ask for a swap to the more appropriate gear
I wouldn't ask that Garry Edwards chap anything though, he's biased lol
Dave
One other thing. You only want to be using umbrellas with strobes when you HAVE to. Softboxes, in my opinion, give a much better (softer) light.
Yeah. And just ignore the fact that a softbox has two diffusing baffles which a brolly does not, so clearly the light from the two is not the same.
Totally ignore that it's bloody difficult to fix a grid onto a brolly and control light. First black background set up, will soon find out why that's important.
Whatever.
It's all horses for courses. There is no such thing as a 'good', 'bad' or 'better' lighting modifier because every single one of them has both strengths and weaknesses.Yeah. And just ignore the fact that a softbox has two diffusing baffles which a brolly does not, so clearly the light from the two is not the same.
Whatever.
Pressed the button:
Smart flash 2 kit
Octo softbox
Backdrop stand
- busy weekend making space in the office for it all, next up some new glass!
And it depends on context too - even the much maligned shoot through umbrellas, which tend to spill light in all directions and which because of this can produce very uncontrolled light in tiny spaces with white ceilings and walls, can produce pretty controlled lighting in a large studio with black walls and a high ceiling.
Missed this one
The answer to which is better though depends on how you are using it - You're right you wouldn't use a brolly to provide light on a black background, but if you want light to be spread over a larger area, you would probably want to use a brolly....... Horses for courses.
Regards the softbox inner baffle, what that does is spread the light inside to diffuse the hot spot. It doesn't make the light softer which is only about the size of the light source relative to the size of the subject.
I think a softbok really just controls the light better - A brolly spills light everywhere and a softbox provides more direction and control - It's not softer (given the size of the light source relative to the subject remains the same).
Jenny, all modifiers spread light to a greater or lesser degree.You need to look up Softbox 101 and Umbrella 101 on Youtube and see how each modifier and size of modifier actually spreads light.
Then what the heck are those two diffusing baffles doing? And how about the grid?
But the spread of light is totally irrelevant to your argument anyway, all that actually matters is the area (size) of the light, not its spread or, more accurately, the size of the light relative to the size of the subject, which of course is governed by the Inverse Square Law in that if you move the source twice as far away its relative size is reduced to a quarter.
With the greatest possible respect, if you want to advance technical arguments about lighting you first need to understand the technical properties - you can do that by studying physics, or by experimentation - but you probably won't learn much from the average youtube video![]()
As I understand it mainly they're helping reduce hot spots, the design of a softbox is going to be more directional than a reflective umbrella as most are now recessed and of course you can add a grid but the softbox needs those diffusers as most designs have the flash pointing toward the subject while the reflective umbrella will have the head pointing away.
I understand them perfectly well enough to correct you, time and time again.
Why don't you do it, post up a tutorial & help people see your (IMO flawed) point of view. Or just shut up arguing. Either one is fine.I suggest you actually do it and test it and see the difference for yourself.
With my science hat on
Because her photos and knowledge aren't up to it. It's as simple as that.
I've been listening to Garry's advice because of his decades in the industry and experience with lighting.
I WILL also listen to others on the basis of their experience/credentials. Unless you have similar experience, other than quoting you tube 101 videos, it begins to sound like a personal thing.
Also (with my science hat on) it's hard to argue with physics!
S
I quoted the 101 videos because you wouldn't believe me and they prove categorically what you seemed determined not to believe.
Please address the right people.
I never stated that I didn't believe you.....
Also the tone of your messages is unnecessarily aggressive.
I wouldn't dream of telling you to "learn to read" even though it could be applied to your response above.
S
Because I already posted about two tutorials that explain it perfectly well. Suggest you read what I say if you intend to comment on it.
I am bring spoken to aggressively, again. What do you expect? a doormat? Those people who the reply was aimed at know who they are.
You tell me I'm rude when I get messages like, "Because her photos and knowledge aren't up to it. It's as simple as that." which you completely overlook, very selective of you.
Then you end your missive with, "though it could be applied to your response above", an insult.
I have noticed countless people have left these forums because of the attitudes I am finding here. It's a shame because I am sure they were the ones worth keeping!
S
Isn't that nice of her to call my work out like that. As I replied. Show your work Jenny if you claim to be the oracle of retouching and lighting and can do better.
Mind you at £120 for an hour and a half with 5 retouched shots, what would you expect?
I can see you clearly understand itYou need to look up Softbox 101 and Umbrella 101 on Youtube and see how each modifier and size of modifier actually spreads light.
Oh that bit is really easy. Her work is here:
http://www.jgw-photography.co.uk/actor-headshot-portfolio#h3c5c858d
As I said, her work doesn't support her arrogance.
When you have progressed beyond flat lighting maybe you'll be in a position to make better comments.
