Slow startup is normally due to installs dropping stuff into your startup.
Start->Run->msconfig.exe
Look at the startup tab. Do you want all of those things starting?
I did all that last week, only seven boxes ticked.
I have 4 drives installed, my windows experiance is 5.9
floppy drive, dvd drive and the standard built in multi card reader
admirable said:I ran the Windows Performance Toolkit earlier and it says it's Avast causing the slow startup
admirable said:Dell Precision T7500
Intel Xeon E5520 @ 2.27GHz
12GB ram
W7
just coming up for 3 years old
realspeed said:How often have you removed dust from inside the computer? If the vent get clogged up with dust (including one on processor) the computer can build up too much heat and that would also cause a slowdown. With all those hard drives in it maybe the power unit isn't big enough to cope. 6TB on four disks is asking a lot try only 2 hard drive disks with greater capacity. How much RAM do you have? just Adding Disks may need more RAM to help
Realspeed
Heat won't slow a pic down neither will a lower rated power supply. Having more disks will not require more memory.
admirable said:I've just timed it from a cold boot - 8 mins
I have 6 x 2GB SAMSUNG DDR3 PC3 10600R ECC REG DRAM
realspeed said:Maybe not but will slow down his startup time with the number of disks which is the OP's problem.
Odd.. Never seen avast cause a slow load up.
